Date/Time: Mon, 05 Oct 2026 03:24:34 +0000
Real-time Data
View Count: 736
[2022-03-02 16:11:44]
sean.sean - Posts: 5
It's my understanding that after subscribing to the Denali data feed (seeking real-time data), you must choose the data you are looking for (and pay the corresponding fees on top of the Denali feed fee). If this is correct, then you must to have a funded futures account with an approved exchange/clearing house (i.e. your stage 5 easy solution reccomendation). My current broker is not one on your list(TDA), so I have to remedy this (most likely using the easy solution method). I want to verify that all of this correct before continuing.
Thank you for your time.
[2022-03-02 16:27:14]
Yes this is correct if you are requiring real-time futures data from the CME group of exchanges.
Date Time Of Last Edit: 2022-03-02 16:27:28
