Date/Time: Mon, 05 Oct 2026 03:22:40 +0000
I can not connect to DATA
View Count: 795
[2022-03-02 15:47:20]
User752881 - Posts: 9
I've never had a problem,
This is the first time in two years
This is what is listed in error:
Reading Internal Order ID file. | 2022-03-02 10:05:12.622
Reading Trade Orders file. | 2022-03-02 10:05:12.814
Reading Trade Positions file. | 2022-03-02 10:05:12.815
Reading Trade Account Data files. | 2022-03-02 10:05:12.816
UDPListener (1588). Port 22904 | Listening on UDP port 22904. | 2022-03-02 10:05:12.863
Software version: 2270 64-bit | 2022-03-02 10:05:12.864
Primary Thread ID: 2432 | 2022-03-02 10:05:12.864
Usage end date: 2022-03-26 | 2022-03-02 10:05:12.864
Enabled for: Advanced Features 2. | 2022-03-02 10:05:12.864
Enabled for: Sierra Chart Historical Data Service. | 2022-03-02 10:05:12.864
Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-02 10:05:12.864
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-02 10:05:12.864
Current selected Data/Trading service: TransAct WS | 2022-03-02 10:05:12.864
Custom symbol settings values: enabled | 2022-03-02 10:05:12.864
Chart Update Interval: 500 | 2022-03-02 10:05:12.864
Intraday Data Storage Time Unit: 1 | 2022-03-02 10:05:12.864
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-03-02 10:05:12.864
2022-03-02 15:05:12 Local computer time in UTC | 2022-03-02 10:05:12.864
2022-03-02 10:05:12 Local computer time in SC Time Zone | 2022-03-02 10:05:12.864
2022-03-02 15:05:15 Server time in UTC | 2022-03-02 10:05:12.864
Local computer UTC time and Server UTC time difference: 4 seconds. | 2022-03-02 10:05:12.864
Program path: C:\SierraChart\ | 2022-03-02 10:05:12.864
Data Files path: C:\SierraChart\Data\ | 2022-03-02 10:05:12.864
OS Version Number: 10.0 | 2022-03-02 10:05:12.865
Locale Setting: C | 2022-03-02 10:05:12.865
DLLs: UserContributedStudies_64.dll | 2022-03-02 10:05:12.866
Allowed protected custom studies: | 2022-03-02 10:05:12.866
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 1. | 2022-03-02 10:05:12.915
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-03-02 10:05:12.977
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-03-02 10:05:14.464
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-03-02 10:05:14.464
Received 5 login tokens. | 2022-03-02 10:05:15.793
Symbol settings MD5 received. Request ID: 1. | 2022-03-02 10:05:16.960
Symbol settings are up-to-date for transact.trading. | 2022-03-02 10:05:16.960
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-02 10:05:20.207
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-02 10:05:20.207
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2022-03-02 10:05:20.207
Auth Websocket socket (1) | New receive buffer size: 5242880 | 2022-03-02 10:05:20.207
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2022-03-02 10:05:20.207
Auth Websocket | Opening WebSocket. | 2022-03-02 10:05:20.549
Auth Websocket | Sending WebSocket handshake. | 2022-03-02 10:05:20.549
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-02 10:05:23.698
Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-02 10:05:23.698
Auth Websocket | Server header | Connection: Upgrade | 2022-03-02 10:05:23.698
Auth Websocket | Server header | Sec-WebSocket-Accept: cbj5FIrgd9GsaDn4IfWfOxrEpxA= | 2022-03-02 10:05:23.698
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-02 10:05:23.698
Auth Websocket | Server header | | 2022-03-02 10:05:23.698
Auth Websocket | Web socket state is now open. | 2022-03-02 10:05:23.698
TransAct WS | Sending account logon message. Simulated Live | 2022-03-02 10:05:23.698
Service connection timed out. Will disconnect and retry. | 2022-03-02 10:06:20.192 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-02 10:06:20.192
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-02 10:06:20.192
TransAct WS | Session key cleared | 2022-03-02 10:06:20.208
Auth Websocket socket (1) | CloseSocket call. | 2022-03-02 10:06:20.208
Auth Websocket | WebSocket closed. | 2022-03-02 10:06:20.208
TransAct WS | Disconnected. | 2022-03-02 10:06:20.209
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-02 10:06:20.209
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2022-03-02 10:06:22.340
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-02 10:06:22.340
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2022-03-02 10:07:21.110
The message log has been sent to support. | 2022-03-02 10:07:21.110 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2022-03-02 10:07:21.110
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 95.216.233.104. | 2022-03-02 10:07:21.110
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2022-03-02 10:07:24.795
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2022-03-02 10:07:25.040
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2022-03-02 10:07:25.040
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2022-03-02 10:07:26.142
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2022-03-02 10:07:26.142
Auth Websocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-03-02 10:08:32.772
Auth Websocket socket (1) | Closed. | 2022-03-02 10:08:32.772
Auth Websocket socket (1) | Deleting network socket now after delay. | 2022-03-02 10:09:02.781
Symbol settings could not be loaded because there are no applicable files to load. | 2022-03-02 10:10:47.861
Requested symbol settings for service code cqg. Request ID: 2. | 2022-03-02 10:10:47.861
Orders Websocket socket (0) | CloseSocket call. | 2022-03-02 10:10:47.864
Price Websocket socket (0) | CloseSocket call. | 2022-03-02 10:10:47.864
Auth Websocket socket (0) | CloseSocket call. | 2022-03-02 10:10:47.864
Current selected Data/Trading service: CQG WebAPI | 2022-03-02 10:10:47.870
Symbol settings received. Request ID: 2. | 2022-03-02 10:10:53.216
CQG WebSocket socket (0) | CloseSocket call. | 2022-03-02 10:11:20.061
CQG WebSocket socket (0) | CloseSocket call. | 2022-03-02 10:11:20.062
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 3. | 2022-03-02 10:11:20.064
Current selected Data/Trading service: TransAct WS | 2022-03-02 10:11:20.064
Symbol settings MD5 received. Request ID: 3. | 2022-03-02 10:11:25.345
Requested symbol settings for service code transact.trading. Request ID: 4. | 2022-03-02 10:11:25.345
Symbol settings received. Request ID: 4. | 2022-03-02 10:11:29.120
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-02 10:11:31.104
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-02 10:11:31.104
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2022-03-02 10:11:31.104
Auth Websocket socket (1) | New receive buffer size: 5242880 | 2022-03-02 10:11:31.105
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2022-03-02 10:11:31.105
Auth Websocket | Opening WebSocket. | 2022-03-02 10:11:32.715
Auth Websocket | Sending WebSocket handshake. | 2022-03-02 10:11:32.715
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-02 10:11:35.976
Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-02 10:11:35.976
Auth Websocket | Server header | Connection: Upgrade | 2022-03-02 10:11:35.976
Auth Websocket | Server header | Sec-WebSocket-Accept: lT0xL3CFLE8gLb97ih9XOXRahAI= | 2022-03-02 10:11:35.976
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-02 10:11:35.976
Auth Websocket | Server header | | 2022-03-02 10:11:35.976
Auth Websocket | Web socket state is now open. | 2022-03-02 10:11:35.976
TransAct WS | Sending account logon message. Simulated Live | 2022-03-02 10:11:35.976
Service connection timed out. Will disconnect and retry. | 2022-03-02 10:12:31.127 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-02 10:12:31.127
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-02 10:12:31.127
TransAct WS | Session key cleared | 2022-03-02 10:12:31.142
Auth Websocket socket (1) | CloseSocket call. | 2022-03-02 10:12:31.142
Auth Websocket | WebSocket closed. | 2022-03-02 10:12:31.142
TransAct WS | Disconnected. | 2022-03-02 10:12:31.143
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-02 10:12:31.143
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2022-03-02 10:12:32.650
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-02 10:12:32.650
[2022-03-02 16:37:16]
If you are having trouble connecting to Transact, refer to this thread here regarding this:
SC Chart not connecting
