Date/Time: Mon, 05 Oct 2026 03:24:34 +0000
Auto-Trade Management - Complex Order
View Count: 1127
| [2022-03-02 03:01:13] |
| User837393 - Posts: 161 |
Hello, Why would a complex order would work when activated manualy, but when that same order in a trading speadsheet it is not working ? Details : 1. The formulas in the spreadsheet are correct. When using a single contract with a triggered trailing stop limit (with the offset and the trigger programed in the trade window), the auto-trade works, the algo is triggered and the order work. 2. When using 2 contract and adjusting the quantities of stops and target accordingly in the trade window, it works when actioned manualy, but when activating the auto trade it doesn'T work and I get a message logg with an error message. The message says : Trade order error - Trade order Quantity is 1 and this is less than the total of 2 for the attached order. Adjust the order quantities so the parent order s greater or equal to the attach order. ... this does make sense, since my trade order is not 1 but 2, also the order works manualy. Only in auto-trade it doesn't work. Date Time Of Last Edit: 2022-03-02 03:01:58
| [2022-03-02 03:10:40] |
| Sawtooth - Posts: 4355 |
The Spreadsheet System for Trading study uses cell J26 to set the quantity, which overrides the Trade Window quantity.
| [2022-03-02 03:30:40] |
Thanks tomglib, Exactly, I was about to post that I just resolved my issue ... Cell J26 is where we input the contract quantity. ...Learning everyday :) |
| [2022-03-02 12:28:52] |
You need to set the order quantity on the Spreadsheet as explained: Spreadsheet Systems, Alerts and Automated Trading: Order Quantity (read / write) [v1:J26, v2:J69] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-02 12:29:23
