Date/Time: Sat, 31 Oct 2026 20:11:55 +0000
Automated trade management - Reversal
View Count: 1245
| [2022-03-01 20:02:52] |
| User837393 - Posts: 161 |
I have a very simple trading system made through the use of spreadsheet. The trades entries are executed as per the column K and M. However I'm trying to use the reversal entries, but it doesn't work. I thought that I would only have to set ln:22 (Support reversal) to make the current position flatten and action the opposite signal as per Automated Trading Management: SupportReversals My entry consist of a limit order (as per column K or M) with its stop, but the opposite entry is not trigered. The other option to solve my problem, is a little clever. I could program the opposite trade into column L & N. This way the opposite entry of a long signal would be in column L and the opposite entry of a short signal would be into column N ... not sure if I make sense. Date Time Of Last Edit: 2022-03-01 20:12:42
| [2022-03-01 21:35:22] |
Solved. Thank you. |
