Date/Time: Mon, 05 Oct 2026 03:21:50 +0000
Settings charts: when I change bid column background, I can't change ask column background
View Count: 718
| [2022-03-01 19:29:32] |
| User966676 - Posts: 4 |
Subject updated from 'Denali Exchange Data Feed Agreement' to 'Settings charts' -------------------------------------------------------------------------------- Hi Sierra Chart Team, I've some issues to configure the dom of chart. For example when I change the bid column background, I can't change the ask column background. I don't know what is going wrong. I need your help. |
| [2022-03-02 17:17:50] |
| John - SC Support - Posts: 48095 |
Make sure you are trying to set the correct background for the particular columns you have displayed and that you are selecting the Bid/Ask for the same column. For instance, there are graphics entries for the following items: - Chart DOM Buy Column Background - Chart DOM Sell Column Background - Chart DOM Bid Column Background - Chart DOM Ask Column Background If you have the Buy or Buy/Bid column displayed, then you would need to activate the Chart DOM Buy Column Background, otherwise, you would activate the Chart DOM Bid Column Background. Then you would do the same for the Sell/Ask side. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
