Date/Time: Sat, 31 Oct 2026 20:13:09 +0000
SC DOM - can't find the answer
View Count: 715
| [2022-03-01 15:42:57] |
| User184014 - Posts: 4 |
I've search this board and the web and I can't find the needed answers. I just have two questions about the DOM: 1. I've added the P & L column....how do I change the back ground color of the column (I found how to change the text color)? 2. the 1st column column displays Qty, Status, P&L....is it possible to I remove the P&L part (since I'm using the P&L column)? That's it. Bruce |
| [2022-03-01 18:08:06] |
| John - SC Support - Posts: 48377 |
1. There is not a control for the background of the P&L column. 2. We are assuming that you are referring to the Order Line. Refer to the following for the start of the items you can control on that line: Global Trade Settings Windows: Order Quantity (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-03-01 18:38:58] |
Much appreciated and thanks for the quick response.
