Date/Time: Mon, 12 Oct 2026 02:52:02 +0000
Changing Font ON TIME and SALES
View Count: 985
| [2022-02-28 19:25:02] |
| User216960 - Posts: 6 |
I seem to be able to change colors but when i set the font size and style to something different, It doesn't respond. What am I doing wrong? Thanks in advance
| [2022-02-28 23:28:32] |
| Sierra_Chart Engineering - Posts: 25138 |
The font change does not going to effect right away. You would have to wait for a new time and sales record.
| [2022-03-04 13:40:13] |
BUT i have closed the time & sales window and re-opened it ...even on other chartbooks, and it still doesn't seem to change.
| [2022-03-04 14:28:12] |
There are two Graphics Settings Windows. Check to make sure you are using the correct one. Refer to: Graphics Settings: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
