Date/Time: Sat, 31 Oct 2026 18:09:05 +0000
Moved to Teton but account shows tt_order_routing.dtc.trading
View Count: 986
| [2022-02-22 22:27:13] |
| opmetal - Posts: 74 |
Yesterday I moved to Teton with Stage5 but my account is still showing tt_order_routing.dtc.trading. Do I need to change anything? Thanks.
| [2022-02-22 23:29:57] |
| Sawtooth - Posts: 4359 |
Same for me
| [2022-02-23 01:30:00] |
Yes you do. You need to follow the instructions starting with step 7 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-23 01:31:00
| [2022-02-23 01:40:53] |
My apologies, I should've specified that I have already followed these steps.
| [2022-02-23 01:55:03] |
What is Global Settings >> Data/Trade Service Settings >> Current Selected Service set to?
| [2022-02-23 01:56:04] |
Sorry, disregard the prior post, we misunderstood. We removed the TT account from your Sierra Chart account. You will not see that any longer.
| [2022-02-23 02:08:05] |
Please do the same for me.
| [2022-02-23 02:08:36] |
This is done.
| [2022-03-24 23:50:04] |
| User796776 - Posts: 95 |
| [2022-03-25 07:57:09] |
This is done.
