Date/Time: Fri, 26 Apr 2024 21:21:45 +0000
Question about Nasdaq totalview
View Count: 2980
[2022-04-19 14:06:07] |
User430672 - Posts: 15 |
We will be offering the full consolidated tape trades, quotes and volume through the Denali Data Feed as soon as possible. This is already available now through the Sierra Chart Exchange Data Feed:
Sierra Chart Exchange Data Feed You can still activate the US Equities exchange with that data feed. Thanks - I did not realize we could still use SCEDF. I am currently on a six month plan for SC plus Denali: if I switch to SCEDF would the remaining time be automatically pro-rated and credited towards the new service? |
[2022-04-20 02:44:13] |
Looking forward to the consolidated feed through Denali. In the meantime I'm happy to use Sierra Chart Exchange Data Feed, but can't find it listed in the available packages through the account dashboard. Am I missing it there or perhaps there is another spot to find the data feed you mentioned? Thanks. |
[2022-04-20 07:59:19] |
You can activate the Sierra Chart Exchange Data Feed here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Thanks - I did not realize we could still use SCEDF. I am currently on a six month plan for SC plus Denali: if I switch to SCEDF would the remaining time be automatically pro-rated and credited towards the new service? In regards to this, what you can do is change to Service Package 3 or 5 which do not include the Denali Data Feed. You can do this anytime:To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-20 07:59:44
[2022-04-20 08:35:04] |
BenjFlame - Posts: 305 |
User430672, Indeed, to have the barchart consolidated feed with SCEDF, activate this: U.S. Equities (NYSE, NASDAQ, AMEX)
Market Depth Included: No Symbols: New York Stock Exchange, NASDAQ, NYSE MKT 10.50 USD / month. Date Time Of Last Edit: 2022-04-20 08:35:47
[2022-10-23 03:20:16] |
User434158 - Posts: 5 |
Maybe you're aware of this, https://databento.com/ will be offering a consolidated trades tape (CTA/UTP SIP). They're having some issues going live with their US Equities data drop, but I was told last week that they're looking at resolving their issues by mid/late November (previously was early then mid October). Is SC still working on including the consolidated trades tape with the market depth data feed through Denali? If so, any idea on when it may be available? Date Time Of Last Edit: 2022-10-23 08:25:49
[2022-10-26 09:14:01] |
Sierra_Chart Engineering - Posts: 14106 |
Yes and it should be before the end of the year: Is SC still working on including the consolidated trades tape with the market depth data feed through Denali? If so, any idea on when it may be available?
[2022-11-26 07:11:06] |
User410196 - Posts: 29 |
Any chance on that before the next year?
[2022-11-26 18:39:22] |
This is being worked on. Whether we have the full consolidated tape data feed available, independent and separate from our current US equities data feed through the Sierra Chart Exchange Data Feed, before the end of the year, probably not but it is in progress. There are many elements to it that go well beyond technical integration which is really only a very small part of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
