Date/Time: Sat, 31 Oct 2026 20:46:47 +0000
Add historical chart data manually to existing data file.
View Count: 765
[2022-02-22 03:15:15]
User629461 - Posts: 213
Hi, I want to add additional historical daily/wkly/mthly data for some Binance crypto symbols which I have on file (as data only starts from late 2020). Whats the most practical way to do this? Thanks.
[2022-02-23 15:22:51]
That data we have for Binance only goes back as far as what you are seeing. Therefore, it is not possible to get data from us for earlier than that.
If you have the data and want to import it, then refer to the following:
Exporting and Importing Intraday Data Files: Import and Load
[2022-02-27 00:34:48]
Thanks John, can you clarify 2 things:
1) can i import daily data (as opposed to intraday which the above link refers to)
2) can i append to the existing Sierra Chart daily file
[2022-02-28 16:30:40]
The information at the following page gives information related to the file format for Daily files.
Also, the .dly files are stored as ASCII (plain text), so you can just append your information into the file.
