Date/Time: Sat, 31 Oct 2026 20:11:59 +0000
Overseas users for Teton Futures Order Routing
View Count: 929
| [2022-02-19 04:52:21] |
| User480295 - Posts: 15 |
Hi, I am trading from Singapore. Will the speed be affected if I am not based in US? Currently I am on the CQG Singapore server because I find the CQG US server somewhat slower. Thanks. |
| [2022-02-19 14:03:41] |
You actually should have lower latency. Not between your location and the server. But with the actual speed of order processing. In our experience, an intermediary server, like CQG has in Singapore, only works to increase order latency. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-19 14:03:54
