Date/Time: Wed, 28 Oct 2026 20:14:32 +0000
Vertical Text Alignment through ACSIL
View Count: 1454
[2022-02-15 16:41:54]
kas64h - Posts: 87
I'm generating user drawn line drawings through ACSIL, and explicitly aligning the text using Tool.TextAlignment = DT_BOTTOM | DT_RIGHT; or Tool.TextAlignment = DT_TOP | DT_RIGHT; etc.
However, when using ACSIL to make any modifications to the drawing (NOT Text Alignment), the vertical text alignment is being lost and continually reverts to TOP (or DT_TOP in code).
When debugging I can see that Tool.TextAlignment is ONLY returning the horizontal component of the drawing, and the vertical component is being lost (or not read).
Hence, when the drawing is re-drawn, i.e. Tool.AddMethod = UTAM_ADD_OR_ADJUST; sc.UseTool(Tool); the text is always vertically top aligned (whereas beforehand it may well have been bottom aligned).
I've only just noticed this, so it must be something that's only recently occurred (behaviour has been seen in version 2351 and current version 2355, not certain how far back it was working correctly).
Could you please take a look, as when making bulk changes to drawings through ACSIL this is causing a lot of problems.
Many Thanks.
[2022-02-17 07:05:44]
kas64h - Posts: 87
Update:
After receiving an email regarding "Free US Stock Market Depth/MBO Data Feed for Sierra Chart User Base Delayed/Real-time", I have updated to the latest PreRelease (version 2357).
Unfortunately, this vertical text alignment problem remains the same.
[2022-02-17 23:18:33]
Sierra_Chart Engineering - Posts: 25302
We are checking on this.
[2022-02-17 23:39:11]
We determined the cause of this and this will be solved in the next release.
