Date/Time: Sun, 01 Nov 2026 13:46:12 +0000
Data Choice
View Count: 870
| [2022-02-14 21:07:27] |
| Marlin46 - Posts: 34 |
Recently I renewed and chose the Denali feed because of the Transact separation. There are several options on the Data/Trade Service Settings that look like they might work. Which one specifically do I choose in the drop down for Data now that I am completing a switch over from Transact. Thanks.
| [2022-02-14 22:08:59] |
So did you now move to a different broker? If so, what broker?
| [2022-02-15 00:48:10] |
I am using Stage 5... which choice do i use in dropdown?
| [2022-02-15 01:20:42] |
In this case you will follow the Teton Order Routing Service instructions: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
