Date/Time: Sat, 28 Nov 2026 12:52:15 +0000
Issue when selecting a chart
View Count: 802
| [2022-02-14 13:30:27] |
| User143517 - Posts: 68 |
hi there, I am experiencing some issues when selecting a chart within a chartbook, on the lower tab where they are displayed for selection. I have got 13 charts in this specific chartbook, but interestingly, I am not being able to even click from the 4th until the 8th chart, from left to right. The only 2 ways I am being able to access them are by hitting the F4(Previous chart) or F9(next chart) shortcut commands or if I minimize all other windows. Have you guys seen something similar? I am wondering if I have locked these charts somehow without knowing. I even updated SC to the latest version and it did not work. Thanks in advance. |
| [2022-02-14 14:51:06] |
What happens when you left click on those particular tabs?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-14 14:51:12
| [2022-02-14 15:07:06] |
Actually, nothing. I could not even select any of them. However, everything returned to normal now. I will let you guys know if this happens again. Thank you. |
