Date/Time: Sun, 01 Nov 2026 13:45:46 +0000
6CM11-CME[M] Intraday History Issue
View Count: 825
| [2022-02-13 20:14:53] |
| PeaceFrog - Posts: 122 |
Hello, Thank you for taking the time to address this issue. For the 6CM11-CME[M] Intraday chart, Sierra Chart is only producing history back to 2011-Feb-21 at 15:03:00. Intraday charts usually produce history for at least the last 5 months. Kindly advise. Thank you. |
| [2022-02-14 00:25:08] |
| 1+1=10 - Posts: 270 |
If it is tick data you may have found the beginning of the symbol's data: Tick by tick data for futures contracts on the CME/NYMEX/COMEX/CBOT begins at 2011. Prior to this the CME/NYMEX/COMEX/CBOT data is in 1 minute units and begins at June 2008.
From here: Sierra Chart Historical Data Service: What is Included |
| [2022-02-14 00:42:41] |
Hi 1+1, Thanks for taking the time to respond. The charts are Minute charts, not tick by tick. |
| [2022-02-14 14:46:52] |
This is sufficient history for a Continuous Futures Contract Chart and if that is all that is available, that is all that there is for that contract: For the 6CM11-CME[M] Intraday chart, Sierra Chart is only producing history back to 2011-Feb-21 at 15:03:00.
We cannot help further with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-14 23:04:22] |
I understand that you may consider this to be sufficient or a Continuous Future Contract Chart, however, it is not the complete history for this contract. All other contracts have at least 5 months of history. This one has less than 4 months available. Kindly upload the complete history for this contract. I would greatly appreciate you help with this. |
