Date/Time: Mon, 02 Nov 2026 21:15:25 +0000
Nasdaq Total View; XLC missing
View Count: 860
| [2022-02-13 17:27:28] |
| User283743 - Posts: 38 |
Communications sector (XLC) is the 5th heaviest weight in the Spy etf, please add this symbol. |
| [2022-02-13 18:33:58] |
This symbol is supported. It is: XLC-NQTV Even though you do not see it listed, it is supported and you will receive data for it. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
