Date/Time: Sat, 28 Nov 2026 12:52:14 +0000
Extended Line for Price level provided by study / spreadsheet
View Count: 1543
| [2022-02-13 14:06:07] |
| User183843 - Posts: 12 |
Dear SC, it may be a simple question, but unfortunately couldn't find a solution for my problem. I have a price level, where I want to draw horizontal line on my chart. The source of the pricelevel is either: - another study - spreadsheet value I require below options for the drawing of the horizontal line: - extended line until further intersection - line with a defined lenght (xx bars or xx minutes) Could you help me how to achieve this? thanks! PS: I posted it as a "user discussion" in the first attempt - don't exactly know if SC support will reach such, that's why I replaced it by this request. |
| [2022-02-14 10:08:04] |
You really need to use ACSIL for this. Refer to: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) And this ACSIL function and information: ACSIL Interface Members - Functions: sc.AddLineUntilFutureIntersectionEx() ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function ACSIL Programming Concepts: Direct Programmatic Interaction with Spreadsheet Sheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
