Date/Time: Sat, 28 Nov 2026 12:52:13 +0000
[Programming Help] - How to access future price data(in the downloaded dataset) in a study
View Count: 908
| [2022-02-13 13:54:53] |
| User395175 - Posts: 104 |
Hi, is it possible to access future data when programming a study. For example, i want to get the mean of next 20 close prices in the history dataset.(assuming i already downloaded the next 20 close prices)
| [2022-02-13 15:52:25] |
This is not clear for us, but if the data is in the chart it is accessible. Refer to: Working with ACSIL Arrays and Understanding Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-13 17:39:56] |
Thank you for answering it. Maybe i can use sc.Index+1, sc.Index+2.... to access future data on chart?
| [2022-02-13 18:36:25] |
No that does not make sense, but you can fill in Study Subgraph elements, into the extended / forward area of the chart. How this works is explained here: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].ExtendedArrayElementsToGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-14 00:35:12] |
| 1+1=10 - Posts: 270 |
If the next 20 close prices are already downloaded then you just need manual looping which is explained in the link SCEngineering sent which has an example that I'll summarize: // Loop through all the chart bars: for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; Index++) { // For each bar's 0 subgraph output the bar's high - low sc.Subgraph[0][Index] = sc.BaseData[SC_HIGH][Index] - sc.BaseData[SC_LOW][Index]; // Make sure 20th bar into future exists if (Index + 20 < sc.ArraySize) { // For each bar's 0 subgraph output the high of the 20th bar into the future. sc.Subgraph[0][Index] = sc.BaseData[SC_HIGH][Index + 20]; } } |
| [2022-02-14 12:10:19] |
Thank you very much!
| [2022-02-14 13:13:54] |
Sure! Oh, obviously you can’t use the same subgraph to output two different data points so in the example they should not both be subgraph 0.
