Date/Time: Sat, 28 Nov 2026 12:52:13 +0000
[User Discussion] - controlling order executiuon per study
View Count: 903
[2022-02-13 08:19:25]
User61576 - Posts: 458
I have an old SC study I bought a few years back (i have dll only) and found out that it also sends orders to the exchange.
I would like to use the signal to trade manually but without its order execution.
is there is a way to:
1. set the problematic study in SC instance 2 (which will be in sim. mode) and call it with price overlay study into my main SC instance?
2. set the problematic study in a chart without the ability to trade? how? how can i copy the signal to my main chart which i have more studies?
[2022-02-14 00:44:15]
1+1=10 - Posts: 270
If the study provides visual indicators of signals, you can use it on the main chart/instance (to see the signals), while removing its ability to send orders by unchecking the setting from title bar menu at "Trade" -> "Auto Trading Enabled - Chart".
Date Time Of Last Edit: 2022-02-14 00:45:14
[2022-02-14 05:46:06]
in that way you suggested will I be able to trade only manually?
what if I have another cht with charts that are auto trading?
from what I have seen if I use overlay study it copies its trading abilities as well (which was not expected. i want only the chart signals)
I am looking to control the study itself not to send order vis SC menus
[2022-02-14 11:14:33]
User907968 - Posts: 888
"Trade" -> "Auto Trading Enabled - Chart" applies to the active chart, therefore the other charts with autotrading would not be affected.
Trade Menu: Auto Trading Enabled - Chart (Trade menu)
Do as 1+1=10 suggests, then overlay the signals onto the required chart.
