Date/Time: Sat, 28 Nov 2026 12:52:14 +0000
Please can you update new information about :
View Count: 955
| [2022-02-12 19:59:14] |
| Alv P - Posts: 37 |
Upcoming Data Feed Plans 2, New Exchange Thanks |
| [2022-02-12 22:51:00] |
| 1+1=10 - Posts: 270 |
There’s a continuation of that topic here: How to Use New NASDAQ Total View Data Feed
| [2022-02-13 01:35:30] |
What is your question?
| [2022-02-14 13:40:27] |
| Alv P - Posts: 37 |
Hi @SierraChartEngineering Why I am experiencing delayed data in (NASDAQ TotalView-Realtime) If I have activated NASDAQ US stock data and SC data all services ?
| [2022-02-14 14:36:03] |
You must update Sierra Chart to the current version. You are running an unsupported version for NASDAQ. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
