Date/Time: Wed, 25 Nov 2026 21:06:10 +0000
ETH/BTC data
View Count: 1672
[2022-02-09 17:51:14]
User525965 - Posts: 180
Hi, is there a way to feed in data from a crypto exchange like Coinbase into my Sierra charts?
Also, I see BTC and MBTC symbols in my list, but I can't find ETH anywhere. Can you assist?
thanks
[2022-02-09 19:01:54]
John - SC Support - Posts: 48659
We have data from the following:
- Binance
- Bitfinex
- BitMex
- Deribit
But we do not have data from Coinbase.
For each of these exchanges, you need to go to the Find Symbol window and open the section for the particular exchange you want and select the item that states Get ??? Symbols. Then select the button towards the bottom right that states Get Symbols. It may take a few seconds, but you will then get the full list of symbols for that exchange. You can look through those to find ETH.
[2022-02-09 19:35:47]
Ok thanks I will work on this.
I was referring to ETH futures for the second question. Shouldn't that be available on CME? Its not listed (see attachment) but BTC and MBTC are.
imageScreenshot_1.png / V - Attached On 2022-02-09 19:35:23 UTC - Size: 28.91 KB - 436 views
[2022-02-09 21:41:13]
It looks like you are asking about that symbol when you are connected to the Trading Evaluator. We double-checked and it is available when you are connected to CQG, which appears to be what you are connected to now.
We will pass along that you want to have ETH added to the list of symbols for the Trading Evaluator.
If we have the information incorrect above, please let us know what service you are connected to where you do not see ETH.
[2022-02-10 02:15:31]
Yes, that's correct. I was on the evaluator at the time. I do see it on CQG
Thanks!
