Date/Time: Sat, 31 Oct 2026 19:12:16 +0000
Hide Level
View Count: 979
| [2022-02-09 13:39:44] |
| User731023 - Posts: 167 |
I use the Hide Level tool often to hide Fibonacci lines at times. After downloading version 2351 I can not get the Hide Level to work anymore. I looked to see if the Hide Level tool had to be enabled in new version. Under Hide Level instructions, it does not say you have to. Please advice |
| [2022-02-09 16:25:24] |
| John - SC Support - Posts: 48377 |
We just tried this in version 2351 and 2353 and we can remove levels without any trouble. What method are you using to remove a level? If you are doing it from the Drawing Properties window, make sure you have the cursor in one of the fields for the level you want to remove and then select the - (minus) button. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-09 17:21:36] |
Definitely no issue with hiding drawing levels. And nothing has changed with this functionality.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-09 17:21:45
| [2022-02-09 22:21:11] |
Thank you for the quick response. Just to pass it on. After your reply I went back and tried again to no avail. What I did discover is that if you are using the pointer tool it does not work. You have to use the hand tool. (Select that in control bar) PS Truth be told I do not even remember clicking to use the pointer tool. I never use it. As you know the hand tool is a pointer until you left click the mouse. That is why I did not notice that I was on the pointer tool before. |
| [2022-02-09 22:31:37] |
Crap! I hate wasting your time. On further discovery it was a malfunction in my Logitech mouse. It works as it should and you intended. On everything... |
