Date/Time: Fri, 06 Nov 2026 23:32:53 +0000
Order Type UNK - Removable Drive
View Count: 700
| [2022-02-09 00:22:42] |
| User412102 - Posts: 5 |
I used Sierra Chart on a remote computer via a removable SSD. I copied my Sierra Chart folder to the removable drive from my desktop. I successfully traded using the remote computer and the removable drive. When I returned to my desktop, I copied the Sierra Folder from the removable drive to the desktop drive. When I look at my order fills on a chart, they show UNK as the order type. When I look at the order fills on the activity log the order type is missing. Is this normal? What is the recommended procedure for using a removable drive and Sierra Chart? The remote computer was a MacBookPro running Parallels. |
| [2022-02-09 14:33:32] |
| Sierra_Chart Engineering - Posts: 25392 |
You need to make sure the files in the TradeActivityLogs subfolder in the Sierra Chart installation folder have been copied.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-09 14:33:41
