Date/Time: Thu, 05 Nov 2026 01:51:11 +0000
[Programming Help] - average percent change
View Count: 996
[2022-02-05 13:16:58]
User156295 - Posts: 105
How to get Average from Percent Change Since Open value from different symbols?
There are different symbols on each chart or symbol on one chart added by add additional symbol study.
Than we have Percent Change Since Open study on each symbol.
And now how to obtain average from these percents - to be able to show on the chart.
Seems to be quite simple but really do not know how to get it...
[2022-02-05 17:03:45]
ForgivingComputers.com - Posts: 1251
You need one copy of the Percent Change study for each symbol. Then change the "Based On" setting to each Additional Symbol.
Then Add a Moving Average Study for each percent, each Based on one of the Percent Change Studies. Input Data needs to be set to Percent Change.
[2022-02-06 10:23:57]
Hmm
I need rather smth like this:
data:
symbol 1 -> percent change since open value 1
symbol 2 -> percent change since open value 2
symbol 3 -> percent change since open value 3
calculation should be:
median = (value 1 + value 2 + value 3)/3 *100
result in % and best if ploted as bars on time dependent chart
and would need some hint how to obtain this in SC
[2022-02-06 23:19:55]
Use a Spreadsheet Formula Study with the ID and SG of each of the percent change studies and draw it as a bar.
value 1 = ID1.SG1
value 2 = ID2.SG1
value 3 = ID3.SG1
So the formula will be:
= 100 * (ID1.SG1 + ID2.SG1 + ID3.SG1) / 3
