Date/Time: Fri, 06 Nov 2026 04:28:58 +0000
Market data for CME, Eurex, LIFFE + ICE Europe, most efficient way
View Count: 1011
| [2022-02-01 16:26:23] |
| rshimmin - Posts: 42 |
Now that I can't get LIFE and ICE Europe through SC data. What is the most efficient way of receiving CME, Eurex, LIFFE and Ice Europe data through Sierra Charts? Thanks |
| [2022-02-01 17:25:51] |
| John - SC Support - Posts: 48449 |
You can get the CME and EUREX data from our Denali Exchange Data Feed, which you are currently setup to do. For the other data, you would need to check with IQ Feed to see if they have it available. Refer to the following: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-02-02 08:37:25] |
Ok thanks but if I use Denali and IQ feed I have to run 2 x sierra charts software. This is a bit clunky moving between each open software, is there not a more efficient way?
| [2022-02-02 18:13:18] |
There is not another option.
