Date/Time: Fri, 13 Nov 2026 19:41:57 +0000
display correctly data
View Count: 902
[2022-01-29 17:44:47]
User278398 - Posts: 296
hello,
by "spreadsheet formula" study i can display any value i want
(by "study subgraph above/below bar as text" study)/
the problem is depend the bar...
i'm trying to find other solution like the "number bars calculated values" study which display by table...
1. any way to get the value that i get form spreadsheet formula" study and implant it inside the TABLE of "number bars calculated values" study?
2. any other way?
thank you all
[2022-01-30 08:26:42]
someone ?
[2022-01-30 17:37:00]
1. You could do this with ACSIL. It is also a feature we plan to develop to make any study display as a table but it is not supported yet.
[2022-01-31 08:55:15]
after over the steps to build an ACSIL, i was required to download and install the compiler...
which i need to install to proceed ?
refards
image1.png / V - Attached On 2022-01-31 08:54:58 UTC - Size: 502.59 KB - 301 views
[2022-01-31 18:38:18]
You only need to download the compiler if you are needing to compile locally for some reason. Otherwise, use the Remote Compile option to compile your DLL on our server.
