Date/Time: Sat, 07 Nov 2026 18:19:54 +0000
i am triggered into 2 contracts when 1 is selected
View Count: 741
| [2022-01-28 13:14:07] |
| User531621 - Posts: 144 |
Hello, i have had this problem before, and its happening again.. I have traded for 4 years so i know how to work the DOM - it clearly says 1 contract, but its triggering me into 2. I would love this looked into and fixed please. Thank you so much
| [2022-01-28 17:14:08] |
As long as the order quantity is set to 1 on the Trade Window, And you have two separate orders, then the problem must be with the interaction with your input device or your input device. There must be, 2 events going to the order entry column on the Chart/Trade DOM assuming that is how you are entering the order. There definitively is not any problem on the Sierra Chart side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-28 17:14:38
