Date/Time: Sat, 28 Nov 2026 12:12:02 +0000
Daily Stock Bars
View Count: 938
| [2022-01-24 17:14:12] |
| wingz - Posts: 121 |
Why are the bars on my historical stock charts not updating? It's 12:10 PM Eastern time on 1-24 and the most recent bar on my daily charts is 1-21. I've used the Delete and Download Data several times and it does not update the bar to today's bar. It did this last week also. I didn't get a current daily bar until after the close on 1-21.
| [2022-01-26 16:49:56] |
| User37462 - Posts: 33 |
The same to me. I cannot see actual price of historical stock if I reload the chart. I can see the previous days, except for today. Iam sure it was possible last week. |
| [2022-01-26 17:17:26] |
This was a change made by our data provider which is out of our control. With our new NASDAQ data feed coming out next month, all of our users will have access to the delayed data feed if you do not pay the exchange fee and this will be a solution to this problem. You will have access to NASDAQ and NYSE and AMEX stocks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-26 17:18:34
| [2022-01-26 21:29:46] |
OK........let me be sure I'm understanding what you're saying. The data provider has changed the data on historical daily stock charts so that they do not update at all during the day and this is going to be the case going forward? If that's the case.......don't you think it makes your daily stock charts almost worthless?
| [2022-01-26 22:17:16] |
Correct. and this is going to be the case going forward?
This is what the current vendor is going to be doing going forward. But we have been working on a new U.S. Equities data feed of our own, which will not have this issue when it is available. We are hoping to have it ready in February. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-27 04:23:01] |
OK..........sounds good
| [2022-02-14 08:45:43] |
But we have been working on a new U.S. Equities data feed of our own .... We are hoping to have it ready in February.
This is the: New NASDAQ Total View Data Feed? |
| [2022-02-14 09:43:32] |
Yes this is correct. Here is the documentation for it: How to Use New NASDAQ Total View Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
