Date/Time: Mon, 16 Nov 2026 16:35:07 +0000
Intraday and Swing Trading The Same Symbol
View Count: 1073
| [2022-01-20 00:54:25] |
| User379468 - Posts: 508 |
What's the correct method in Sierrachart to both intraday and swing (longer term overnight holds) trade the same symbol, while managing positions, orders, and trades independently?
| [2022-01-20 05:16:42] |
| Tony - Posts: 733 |
I assume you have to day trade and swing trade same symbol in different accounts ?
| [2022-01-20 13:47:29] |
I think that would make it simple, this is for in the same account in this situation now.
| [2022-01-20 14:43:21] |
| Tony - Posts: 733 |
I don't know how it can be done, i.e. if you have a long swing position, to open a short day trade position would flat all or some your long position? |
| [2022-01-20 15:58:25] |
Yes, that is ok, just want to manage them separately.
| [2022-01-20 20:20:31] |
There is no specific support for what is described in post #1. However, do have a look at this feature here: Trading Information Windows: Using Order Fill Calculated Trade Positions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-21 02:04:57] |
So by following these instructions: Basic Trading and the Trade Window: Using Order Fill Calculated Trade Position Data for Independent Position Tracking Will it work correctly to trade live how it's described in Post #1? |
