Date/Time: Wed, 25 Nov 2026 19:07:36 +0000
Market Depth Historical Graph study info not showing
View Count: 993
[2022-01-19 02:40:35]
dvant krypto - Posts: 43
Hi..... I have SP11 and the study mentioned above is not putting the bids/offers on the chart. When I go back one week, the info is there. When I open the market depth window, the info is there. Everything was working fine up until last Friday. I am using the most recent SC install. Any ideas?
[2022-01-24 15:45:33]
John - SC Support - Posts: 48658
It must have something to do with the settings you are using to display the data. Our recommendation would be to remove the Market Depth Historical Graph that you have on that chart and add a new one. Then with the default inputs for the MDHG see if you are able to see the data where you were not able to previously. If the data is there, then you need to look at your inputs and see how what you had set would make the data not show up for that particular time.
Also, refer to the following to ensure that you are downloading missing historical depth data:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
If you are still having an issue, then we need to see an image of what you are seeing, preferably with the last bit of data that you can see showing in the chart as well.
