Date/Time: Sun, 01 Nov 2026 07:50:50 +0000
Denali Data Delay through DTC
View Count: 799
| [2022-01-18 01:34:23] |
| User873664 - Posts: 18 |
Hello, What is the expected difference from the timestamps received in the MARKET_DEPTH_UPDATE_LEVEL_FLOAT_WITH_MILLISECONDS messages? Is there any additional tests I can run? It appears as though this information is coming through about 400ms after the timestamps (compare local clock to timestamp in message). I am located in West Canada. This was about 700ms but then I set my system clock using Global Settings -> Set System Date Time from server, now it is around 400ms. Thanks for your time |
| [2022-01-18 03:47:02] |
There are so many variables involved here. There is not a way we can answer this.
