Date/Time: Fri, 26 Apr 2024 02:38:29 +0000
[User Discussion] - COT / Commitment of Traders
View Count: 15132
[2021-10-25 13:23:12] |
User575399 - Posts: 305 |
Does anyone already have it compiled? I’m not computer savvy
[2021-10-25 17:33:43] |
Пользователь488020 - Posts: 81 |
I am not a programmer either, but the study of COT.cpp post 36 is loaded, the compiler collects it, but the graph is empty. I take the daily chart of ZNZ21. What needs to be fixed? Who will tell you? |
[2021-10-25 22:40:33] |
Ok, I gotthe study to show up but its blank. Any ideas how to get the quandle API key and set this up? Im using it on a daily chart
[2021-10-26 04:46:37] |
User146848 - Posts: 120 |
You need to have an quandl account...cot is for free.
[2021-12-08 04:58:57] |
DayTraderEsad - Posts: 116 |
I have this, let me know if anyone needs help getting on their chart.
[2021-12-08 07:12:57] |
I have problems with the percentile study based on the commercial net pos given by the cot study. The last data point is always wrong and its always the last/ current one. Happens with percentile study for example. SC means stochastic percentile works as in tented and i believe that. Problem still remeins...for me at least. Can you replicate what you can see on the attached pictures? |
COT Wrong.jpg / V - Attached On 2021-12-08 07:12:46 UTC - Size: 156.07 KB - 531 views COT Right.jpg / V - Attached On 2021-12-08 07:12:53 UTC - Size: 146.94 KB - 627 views |
[2022-08-05 04:03:39] |
toews&kane - Posts: 209 |
@Support are you guys still looking to create this study? Stumbled on this this will be very useful data to see the different market participants, would be a real advantage |
[2022-08-05 13:29:38] |
John - SC Support - Posts: 31131 |
As the saying goes "Never say Never", but it is not something that is high on our priority list.
[2022-08-05 17:25:34] |
ok ok thanks please keep us posted! Let me try to do a workaround, learning how to plot from spreadsheet study; COT publishes the csv's weekly it's just pulling them in
[2022-08-05 17:32:34] |
You didnt get the msg.: Its not going to happen in the next couple of years.
[2022-08-05 17:45:51] |
I have the COT study in a dll - send a DM and I'll just give you access -- pulls data from Quandle (which is now the Nasdaq website) --- you just need to sign up for a API key (free) on their site.
Date Time Of Last Edit: 2022-08-05 18:12:09
[2022-09-05 13:19:42] |
User411320 - Posts: 253 |
Hey DayTraderEsad, I requested permission to DM you for the COT study thanks
[2022-09-05 21:23:44] |
User485461 - Posts: 9 |
Hi @DayTraderEsad can you pls accept permission to DM, I'd like to check the COT Study TIA |
[2023-12-30 19:56:13] |
mbarbhaya - Posts: 35 |
Did we get COT high and COT low with Sierra Charts, as-like these Quantower and Motivwave platform has incorporated Commitment Of Trade with their charts ?
[2024-01-02 16:18:32] |
svltan - Posts: 6 |
Hey @DayTraderEsad, requested access to DM, was hoping I could also get the DLL and source code, if possible?
[2024-01-02 16:54:35] |
I was not able to get to that DLL page
[2024-01-02 17:05:10] |
Do to the vetting channel and write COT or whatever you want…that’s where I go and give access Edit - I found you, you can see it now Date Time Of Last Edit: 2024-01-02 17:06:33
[2024-01-02 17:35:59] |
I did forget to give you the link You will need to create a free Nasdaq account to get a free API and then use that to input in the API key in study settings https://data.nasdaq.com |
[2024-04-25 13:31:28] |
Pau - Posts: 3 |
Hi @DayTraderEsad, I'd like to check the COT Study. Do you still grant access to the study? Thanks |
