Date/Time: Wed, 23 Sep 2026 00:47:17 +0000
EUREX data feed problems Interactive Brokers
View Count: 867
| [2022-01-12 18:27:10] |
| Wouter van Beek - Posts: 2 |
Hello, I'm using the data from Interactive brokers but the trend/data is stoped on 2022-1-7. I had the same problem a while ago but I don't know how to fix this. I'm using the last SC version and have only trouble with the EUREX/DAX data from Interactive Brokers. I'm hoping somebody can help me, I dont know what I'm doing wrong because the other Interactive brokers data feed is stil working. Thanks. Wouter |
| [2022-01-12 18:40:44] |
For access to EUREX data you need to change to Service Package 10. To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
