Date/Time: Mon, 06 May 2024 07:05:33 +0000
Denali Data Feed Does Not Have Real Time Data for Certain CME Group Symbols
View Count: 1627
[2022-11-03 10:10:36] |
User686802 - Posts: 69 |
I saw COR3M from CBOE asked for since Feb 2022, I am switching to Denali from InteractiveBrokers, I need https://www.cboe.com/us/indices/dashboard/cor3m/ -- I have to switch now because of my current package 5 plan ended, now package 11. I really want to stick with Denali but the COR3M is the last bit I still have to use InterativeBrokers for --which is a sad and shameful situation. Why is the specific issue COR3M being ignored and off the radar since Feb ???
[2022-11-07 16:43:06] |
SC Support - Posts: 1797 |
COR3M from CBOE is not available on Denali, if you are looking for access to CBOE Cash Index Data you can either get it from Interactive Brokers or you can get it from the Sierra Chart Exchange Data Feed (operated by BarChart): Sierra Chart Exchange Data Feed The Exchanges Available to you on the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed: Supported Exchanges Set-up instructions: Sierra Chart Exchange Data Feed: Setup Instructions |
[2022-11-07 19:27:00] |
Sierra_Chart Engineering - Posts: 14239 |
We do not think this is available with the Sierra Chart Exchange Data Feed - CBOE Indices: COR3M It is not something we are going to offer if it is not. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
