Date/Time: Sun, 01 Nov 2026 09:20:09 +0000
Removal of ICE Real-time Exchange Data
View Count: 908
| [2022-01-04 22:17:59] |
| Stephan_CH - Posts: 18 |
Thank you for information. One question: means that, it is no more possible to have ICE data by IQFeed DTN within SC at the same time I have Denali for all other symbols at CME? Does I need now a separate instance for ICE or is there any possibility to use it at the same time? Thanks for your support. Kind regards, Stephan |
| [2022-01-05 05:13:39] |
| Sierra_Chart Engineering - Posts: 25338 |
In the case of IQ Feed, you need a separate installation of Sierra Chart. Refer to: Using Multiple Data and Trading Services at the Same Time Although refer to the section at the end of that page for how to access the data in a single instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-05 05:14:08
