Date/Time: Fri, 13 Nov 2026 16:15:08 +0000
Infinity Futures
View Count: 1198
| [2022-01-03 15:11:33] |
| Ajay Karwal - Posts: 2 |
Hello I have a futures account with Infinity Futures. How can I set up Sierra Charts with it? Thanks, |
| [2022-01-03 17:15:48] |
Infinity uses the Transact system and we are in the process of phasing out support for Transact. So you really need to use our Teton order routing service and then choose a broker that supports it. Full information is here: Sierra Chart Teton Futures Order Routing The list of brokers is at step 2 here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-03 17:17:13
