Date/Time: Sun, 01 Nov 2026 09:46:22 +0000
quantity error
View Count: 758
| [2022-01-03 13:28:44] |
| User313942 - Posts: 17 |
hi. i trade bitmex crypto . want set quantity 0.2 or other. wht i have quantity mistake ? how can i use multi targets ?
| [2022-01-03 14:03:08] |
You cannot use fractional quantities for Attached Orders or BitMex. Use 2 only.
