Date/Time: Tue, 10 Nov 2026 14:50:27 +0000
TPO Profile Chart - Show Chart Values On Profile Keeps Resetting
View Count: 1107
[2021-12-22 12:31:54]
User93757 - Posts: 61
REF: TPO Profile Study
The Input Value for "Show Chart Values On Profile (In:113), keeps resetting every time that you restart Sierra Charts.
Ty,
[2021-12-22 13:49:34]
This is not reproducible and it does not make technical sense. There must be some reason why this is happening in your case.
And also this could not be related to restarting Sierra Chart. It would only be potentially related to reopening the Chartbook. Make sure you are saving the Chartbook when closing it.
Date Time Of Last Edit: 2021-12-22 13:50:11
[2021-12-28 09:23:04]
I did some further research.
1) This reset happens when the Chart Values are set to off, When you reopen the book, the Input Value is lost.
2) If the values are set to on, then the input value is saved.
It's obviously is not a big issue, but thought I'd inform your team.
Thank you,
[2021-12-28 16:47:31]
John - SC Support - Posts: 48481
Can you please give us some additional information on what exactly you are seeing, as we are not able to reproduce anything along these lines. Which Inputs in particular are changing and what other Input are they based on?
[2021-12-28 17:18:13]
1) Settings TPO Study
2) Input: Show Chart Values On Profile (in:113) -> Show Chart Values on Profile Without Labels
3) Right Click on Chart -> Select Chart Values On/Off *This will turn OFF the chart values above the TPO Profiles (See Images)
4) Close and save chart book
5) Open chart book
6) Right Click on Chart -> Select Chart Values On/Off *This will turn ON the chart values above the TPO Profiles
7) It is now reverted to the original default value of: Show Chart Values on Profile With Labels in Single Row
When you turn item 3 on/off, the value is saved while working within the session. This does not happen unless you close the chart book.
Hope that helps..
Date Time Of Last Edit: 2021-12-28 17:18:57
imagechartValue.png / V - Attached On 2021-12-28 17:11:45 UTC - Size: 21.55 KB - 347 views
imagechartValue2.png / V - Attached On 2021-12-28 17:17:01 UTC - Size: 34.06 KB - 314 views
[2021-12-31 14:51:17]
Sierra_Chart Engineering - Posts: 25407
We will look this over.
