Date/Time: Sun, 25 Oct 2026 23:22:04 +0000
Countdown Timer
View Count: 843
[2021-12-21 05:07:14]
User841161 - Posts: 357
Was trying to move horizontal position of timer, doesnt appear to change with settings.
imageSettings12-20.png / V - Attached On 2021-12-21 05:06:58 UTC - Size: 235.5 KB - 311 views
[2021-12-21 11:02:38]
User907968 - Posts: 885
It is explained here - Countdown Timer: Moving Countdown Timer
[2021-12-21 23:46:38]
Mercrastius - Posts: 73
Try this:
When you adjust the position using the study settings window, click hide study then Apply. Then unhide it and click OK, it should be in the new position.
Date Time Of Last Edit: 2021-12-21 23:47:52
