Date/Time: Fri, 09 Oct 2026 07:02:21 +0000
Customize Control Bar
View Count: 1072
| [2021-12-13 16:51:05] |
| Marlin46 - Posts: 34 |
Is there a way to save the Control Bar Settings so that I can use a personal setup Control Bar on New Instances? I would like to have the same settings on all charts rather than having to manually Customize the Control Bar for each New Instance?
| [2021-12-13 19:14:08] |
| John - SC Support - Posts: 48161 |
You have to copy the Sierra4.config file from the main installation folder to the Sub-Instance's folders to get the same Control Bars and other graphics settings the same. Refer to the information at the following link, although it is related to copying to a new installation of Sierra Chart, the concept is the same: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Note that the Sub-Instances are located under the main Sierra Chart installation folder and are called SierraChatInstance_2 where the 2 may be some other number depending on the sub-instances you have. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
