Date/Time: Mon, 05 Oct 2026 06:38:37 +0000
VbP - Previous/Last weeek - One Period from Most Recent Period Start to End
View Count: 1887
[2021-12-09 18:28:36]
User405165 - Posts: 5
Hi guys, I found similar requests/solutions but none that applied to my situation.
I would like a VbP that includes data from the previous week only (not including anything this week) - I tried with the value 2 time period length which includes the last two weeks.
Is there a way, shy of manually setting start/end date/time that I can achieve this?
Thx.
[2021-12-09 18:41:24]
John - SC Support - Posts: 48095
If you do not mind getting profiles for every week displayed, then you would set the following:
- Number of Periods Back to Reference: 1
- Volume Graph Period Type: Multiple Profiles Based On Fixed Time
- Time Period Type for 'Fixed Time': Weeks
- Time Period Length for 'Fixed Time': 1
Other items as you desire.
This will give you the display in the current week for the previous week, and so on.
Otherwise, if you want just a single profile, then the only way would be to use the Volume Graph Period Type of From Start Date-Time to End Date-Time and enter the Start and End Date-Times. You would then need to adjust these as the new week started.
[2021-12-09 19:52:19]
Thank you John,
I have these aligned to the right so your suggestion won't work as these are going back too far + they're not aligned to the right.
Is this "feature" something we can request for a future update? I imagine it's not too hard to code.
[2021-12-09 21:46:05]
We are not sure what you mean by this. Aligned to the Right is perfectly fine, just keep in mind that the profile that shows for the current week is actually the data from the previous week. That allows you to see the previous week while viewing the current data.
You might want to use the setting for Always Display Last Profile Within View to Yes. That may solve your issue. Refer to the documentation for this at the following link:
Volume By Price Study: Always Display Last Profile Within View
Yes, we will put this as a Feature Request.
