Date/Time: Sun, 01 Nov 2026 10:28:19 +0000
Show order fills
View Count: 779
| [2021-12-09 10:49:26] |
| arruga - Posts: 253 |
The fill box is showing too far from actual price...can I change these settings so the price box appears next to the bar where the fill occurred? https://www.sierrachart.com/image.php?Image=1639046818704.png |
| [2021-12-09 16:26:24] |
| John - SC Support - Posts: 48377 |
The arrow shows the price where the order fill occurred. The text is put as close to the bar as it can be without overlapping. The only option for where the text is placed is either Above or Below the price point. Refer to the setting at the following link and the one after it: Global Trade Settings Windows: Display Buy Fills (Global Settings >> Chart Trade Settings >> Order Fills >gt; Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
