Date/Time: Mon, 28 Sep 2026 23:08:19 +0000
rithmic Connection
View Count: 1418
[2021-12-07 21:36:19]
User100447 - Posts: 1
Hello, I can't connect the sierra chart platform to rhythmic, I am attaching the log screen
Rithmic Trading | Port for executable: 52322 | 2021-12-07 09:59:21.505
Listening socket (0). Port 52322 | Closed listening socket. | 2021-12-07 09:59:21.505
WSACleanup called. | 2021-12-07 09:59:21.506
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-12-07 09:59:21.506
Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-12-07 09:59:21.511
DTC Client socket (1) | Close event error. Windows error code 10053: Connessione interrotta dal software del computer host. | 2021-12-07 09:59:21.535 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-12-07 09:59:21.535
DTC Client socket (1) | Closed. | 2021-12-07 09:59:21.535
Rithmic Trading | Bridge process is running. | 2021-12-07 09:59:23.533
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52322 | 2021-12-07 09:59:23.533
DTC Client socket (1) | Creating socket. | 2021-12-07 09:59:23.533
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-12-07 09:59:23.533
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-12-07 09:59:23.533
Rithmic Trading | Network connection to server complete. | 2021-12-07 09:59:23.538
Rithmic Trading | Starting socket receive thread. | 2021-12-07 09:59:23.538
Rithmic Trading | Sending encoding request to server: Binary VLS. Compression: none | 2021-12-07 09:59:23.538
Rithmic Trading | Setting DTC encoding to Binary VLS | 2021-12-07 09:59:23.543
Rithmic Trading | Sending logon request message. | 2021-12-07 09:59:23.543
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2021-12-07 09:59:23.548
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2021-12-07 09:59:23.552
Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2021-12-07 09:59:23.552
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2021-12-07 09:59:24.422
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2021-12-07 09:59:24.562
Rithmic Trading | Received logon response. | 2021-12-07 09:59:24.563
Rithmic Trading | Server Name: DTC Bridge. | 2021-12-07 09:59:24.563
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2021-12-07 09:59:24.563
Rithmic Trading | Logon error received from server | 2021-12-07 09:59:24.563
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-12-07 09:59:24.563
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-07 09:59:24.563
Rithmic Trading | Waiting for socket receive thread to end | 2021-12-07 09:59:24.575
DTC Client socket (1) | CloseSocket call. | 2021-12-07 09:59:24.576
Rithmic Trading | Disconnected. | 2021-12-07 09:59:24.576
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-12-07 09:59:24.576
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-12-07 09:59:24.576
File >> Disconnect selected. | 2021-12-07 09:59:24.582
DTC Client socket (0) | CloseSocket call. | 2021-12-07 09:59:24.582
Rithmic Trading | Disconnected. | 2021-12-07 09:59:24.582
DTC Client socket (1) | Close event error. Windows error code 10053: Connessione interrotta dal software del computer host. | 2021-12-07 09:59:46.596 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-12-07 09:59:46.596
DTC Client socket (1) | Closed. | 2021-12-07 09:59:46.596
[2021-12-07 23:04:56]
John - SC Support - Posts: 48044
You are still setup to use the old Rithmic Bridge program. Recent versions of Sierra Chart are no longer supporting the use of that program since Rithmic has put out a new DTC Interface for Sierra Chart.
It is also possible that Rithmic is no longer supporting the use of the old Bridge program, although we do not know for sure.
In the end, our recommendation is to update to the latest Sierra Chart software by using the instructions at the following link:
And then setup your system to use the new interface by following the instructions at the following link:
Rithmic Trading Platform Service: Setup Instructions
[2021-12-08 00:18:03]
If you still cannot connect, you need to ask your broker for help.
