Date/Time: Wed, 23 Sep 2026 13:48:10 +0000
[User Discussion] - SYNTAX ERROR HELP
View Count: 1035
| [2021-12-06 18:59:33] |
| Litz - Posts: 135 |
=AND(CROSSFROMBELOW(AA3:AA6,AB3,AB6),CROSSFROMBELOW(AA3:AA6,AF3:AF6) NOT WORKING JUST A MA CROSSOVER ALERT OF A 5 MA CROSSING 13 AND 21
| [2021-12-06 19:27:16] |
| John - SC Support - Posts: 47980 |
If you copied and pasted the formula, then the problem is that you have a comma where you should have a colon - in the second range of the first CROSSFROMBELOW (you have AB3,AB6, but it should be AB3:AB6).
| [2021-12-06 20:31:52] |
| Litz - Posts: 135 |
TNX STILL GET THE SYNTAX ERROR WITH =AND(CROSSFROMBELOW(AA3:AA6,AB3:AB6),CROSSFROMBELOW(AA3:AA6,AF3:AF6) |
| [2021-12-06 20:38:27] |
| Sawtooth - Posts: 4354 |
The AND needs a closing parenthesis: =AND(CROSSFROMBELOW(AA3:AA6,AB3:AB6),CROSSFROMBELOW(AA3:AA6,AF3:AF6)) |
| [2021-12-06 21:33:23] |
| Litz - Posts: 135 |
YUP that works tnx Tom
