Date/Time: Wed, 23 Sep 2026 13:48:26 +0000
[User Discussion] - AMP and Sierra Chart order routing
View Count: 850
[2021-12-06 15:34:55]
Mhorne - Posts: 7
Good evening,
I noticed this is referenced on the Sierra Chart Support Board: AMP Futures (initial testing phase only) (Clearing firm)
The reference can be found here: Sierra Chart Teton Futures Order Routing
What does initial Testing Phase refer to? Can I be part of the testing phase even if it means Simulated trading?
How long will the testing phase last, I eventually would like to use Sierra Chart CME Direct Order Routing (AMP for Clearing - because of the low costs) and really surprised it's taking this long for AMP to get on board...
Thanks,
Michael
[2021-12-06 17:51:38]
John - SC Support - Posts: 47980
You will need to ask AMP about being put on the trading service early when they have determined that they are making it available. It is not something we can do for you, they will need to do it.
With regards to the status of AMP, we see that the item you referenced has been changed to state AMP Futures (Intending to support. Not yet available.) (Clearing firm). Therefore it would mean that we have not started the process with them yet, but there is the intention to do so from both sides. It's just a matter of when it gets done, which we really can not say as there is a large dependency on AMP in this and we can not speak for them.
