Date/Time: Wed, 23 Sep 2026 13:48:02 +0000
fixed "ruler"
View Count: 655
[2021-12-06 14:53:43]
User138457 - Posts: 60
Is there a way to have a "ruler" of some sort,
fixed to, say, 8 ticks, but movable.
When I use "lock drawing", it also becomes unmovable.
Any help greatly appreciated
[2021-12-06 17:06:37]
John - SC Support - Posts: 47980
Just create the drawing you want (Chart Calculator or Line, for instance) and then select the "Move Drawing" option to move it where you want. It will keep the size you had originally set.
