Date/Time: Wed, 23 Sep 2026 13:48:49 +0000
VBP DOM Bar width
View Count: 873
| [2021-12-05 22:08:04] |
| User585668 - Posts: 2 |
Hello. I would like to know if I can "extend" the volume bars out more. Maximum volume bar width percentage is 100 in VBP DOM study settings and it is still thin. (ES Futures) Volume bars look good (width wise) on a regular chart. But on the DOM its fairly thin. Barely being able to see the actual bar. Any fix? Thank you. |
| [2021-12-05 23:15:22] |
Also. On the DOM. Is it possible to line the volume amount further to the right (volume bars to the left). So the volume numbers aren't "in the way" of the volume bars. Thank you.
| [2021-12-06 16:31:42] |
| John - SC Support - Posts: 47980 |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
