Date/Time: Fri, 18 Sep 2026 10:02:40 +0000
Bug with the Volume at price Threshold study
View Count: 979
| [2021-12-03 19:09:32] |
| User135370 - Posts: 162 |
Hi Please see the attached images. Threshold set at 15, why is it not highlighting everything over 15? I have highlighted the ones it missed. It is an awesome indicator, if I am doing something wrong please let me know if it is a bug can you fix it |
| Attachment Deleted. |
| [2021-12-03 19:21:44] |
| John - SC Support - Posts: 47930 |
There is a newer version of that study called "Volume at Price Threshold Alert V2" that you should use. This older one has not been kept up and it may not be working properly.
| [2021-12-03 19:43:59] |
Thanks John, found it and used it, fixed the issue
