Date/Time: Sun, 01 Nov 2026 11:50:03 +0000
lot size
View Count: 899
| [2021-11-26 19:23:48] |
| User531621 - Posts: 144 |
Hello, data feed is Rithmic... some of the times, when i enter a trade with 1 lot, it will trigger in 2. it has done that about 3 times in the last couple of trading days.. Do you have any idea why that happens? Thank you
| [2021-11-27 17:12:17] |
Make sure you are setting the order quantity on the correct Trade Window: Basic Trading and the Trade Window: Main >> Order Quantity (Quantity) (Trade Window Settings Not Applying to Chart or Trading DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-27 20:02:54] |
Thank you and yes i am setting the order quantity correctly. it was set at 1 but triggered me into 2. Most of the time it is correct, but 3 times so far, it triggered 2 lots.. any other ideas as to why this happens?
| [2021-11-28 15:42:37] |
The only reason this would happen is if your input device, is triggering 2 click left click actions. Exactly how are you submitting the order? And what type of input device do you have. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-28 15:56:48] |
I have the (1) size depressed on the DOM, meaning i am always entering with 1 lot. Never 2 or more at this point in my journey. One click action. My mouse is loud with a click, so i would be aware of i am clicking it 2 times for 2 lots. Very strange
