Date/Time: Wed, 25 Nov 2026 19:07:40 +0000
Spreedsheet periodically store time smaller than 1 minute
View Count: 807
| [2021-11-23 15:30:41] |
| User230940 - Posts: 121 |
Hello, would it be possible to enhance the Spreedsheet periodically storage function to be able to define seconds instead of only 1 Minute as smallest? thanks regards |
| [2021-11-24 01:34:58] |
We do not know what this is referring to: Spreedsheet periodically storage function
| [2021-11-24 08:02:17] |
Hi, sorry. In the Study "Spreedsheet system/Alert" is a function "periodocally save the Sheet as Text" the smallest Value is 1 Minute. My Question is, is it possible to enhance this function to save in Seconds instead of minutes. regards |
| [2021-11-24 13:08:06] |
Yes we can change that to seconds. We will do that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-24 13:08:12
| [2021-11-24 13:09:30] |
Thanks, great
| [2022-01-24 13:45:25] |
This change has been made. Update Sierra Chart to the current version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-24 13:45:34
